Top End Noise
Down on power? Pull the top end down and the problem should be obvious.
I made another video and you can here it better.
https://youtu.be/pIMo3RNXJj0
Was just changing the oil to dino and also noticed excessive metal shavings on the magnet.
Should I assume it's the lifters?
If it was me, it’d be a tear down.
But for ***** I’d cut open the oil filter, check top end, cam chain tensioners, just to see if I could find the root so I could sleep tonight.
Man, sorry to see that. Didn’t know you had +50k miles on her. On a 2016?! Kudos, that’s a lot of riding.
I pulled the top end and everything seems fine. Gonna check the cam tensioner n primary as well.
I'm pretty disappointed.
JVS (06-14-2019)
If the bike seemed to run normal but had a clack, my thinking would be a bolt or pin backed out and was hitting the case. If the crank, cams, valves were coming apart the bike would run like crap. The shrapnel looks like aluminum. Rules out cams and crank.
You can pull the plugs, raise the rear, put in 6th, have someone spin the tire and see if you can stethoscope the case. You might be able to hear where the clack is coming from. Don’t do it without an oil filter in. Look at the cylinder walls through the plug hole. I don’t think it will cause any more damage.
Just throwing out ideas
Yeah. While it was clacking, did the bike run ok? Was there a power drop, miss or smoke?
I just finished pulling the primary and everything looks okay.
I think I might just reassemble everything and take it to the dealer or reputable mechanic.
I'm starting to get in over my head.
JVS (06-14-2019)
