3 hole oil change
https://cimg9.ibsrv.net/gimg/www.hdf...aa9a8661f9.jpg
https://cimg8.ibsrv.net/gimg/www.hdf...985951032.jpeg https://cimg2.ibsrv.net/gimg/www.hdf...b83dcb1fac.jpg So i finally changed the fluids in all 3 holes. Just sharing my experience. Last time i change my engine oil i had overfilled it and had to syphone some out. I had put 2.5 quarts. This time i only put 2 quarts and it was right on the money. Now the transmission calls for 28 fl oz. It was pretty close to that. Almost overfilled that. Seems to be at the full mark. But its also hard to read the dipstick w the fluid being to clear and all. What would happen is the trans was overfilled anyways? The primary calls for 34 fl oz. I had a quart of primary red line, which is 32 fl oz. And i still have a little left in the bottle. So 34 would be overkill. Now what i did the primary i propped the bike up straight with wood under the kickstand. While threading the torx screws in by hand and gentle as ever the bike decided to fall over the opposite side!! I grabed the bike where the seat would be, because i took it off. Didnt help much. But luckly the dog house was on the other side and it leaned up against it as i ran to the other side to put her back up. Long story short i lear that it was pretty sketchy. Im going to have to invest in a jack if im going to continue to do my own work! Whew! 2017 dyna street bob. Mobile 1 in my engine. Red line transmission for my trans. Red line primary in my primary. |
Originally Posted by Gil Aguilar
(Post 18325998)
Do these bikes take different amounts of primary and trans fluids? I'm pretty sure mine calls for a quart in each. Makes it easy...
(Post 1832599)
https://cimg9.ibsrv.net/gimg/www.hdf...4d331ab471.jpg |
Im sure they do take different amounts of fluids. Also depending on your model. But I've learned the recommended amount in the manual isnt always the amount you need.
But in the case of the transmission. It looks like i filled just at the full mark. So i hope thats ok. It really is hard to read the amount on the dipstick. Even if the redline transmission fluid is pink. Ill have to check it at a latter date. Maybe itll get darker to see it better. |
In my experiences with different HD models, I've found that sticking with what the service manual says and not the owners manual, has been on the money every time.
I've found doing my fluid changes (especially oil) with the bike straight up on my lift, it doesn't take as much oil to fill it back up, meaning it's not getting as much out vs draining on the side stand. 2 quarts is really low to get to full, you didn't get all of it out of the pan with the bike straight up like that. There is plenty of room under the bike to do it on the side stand unless your bike is lowered. I use the harley drain pain it fits nice under the bike. Bonus it prevents the bike from tipping over like yours did. Just a bit of help for your next service.
First post 'Gil' you do know that you are supposed to have the bike on the 'jiffy stand' to do the Primary don't you ?
Originally Posted by ThePaintPirate
(Post 18327035)
But i did not drain the oil in all three holes propped straight up. I drained them all on the sidestand leaning regular. I did a 15 minute ride to get it nice and warmed up. I drained the 3 holes immediatley after. Didnt waste time to get the oil out. I only propped it up to add the primary fluid to get an accurate reading according to the manual. I do have the low profile oil drain pan from Harley. It is an awesome item to have. Makes changing the oil easier |
Originally Posted by shodown220
(Post 18327078)
Originally Posted by beanoboy
(Post 18327117)
© 2024 MH Sub I, LLC dba Internet Brands
