End of my rope ~ 02 Dyna With Baker Kicker
Old 07-12-2019, 08:07 PM
NORTY FLATZ's Avatar
NORTY FLATZ
NORTY FLATZ is offline
Received 5,371 Likes on 2,947 Posts
Originally Posted by F86
This is exactly the impression I have of the "easy pull" devices... Since they seem to limit overall travel, I assume the clutch tends to be adjusted either slightly too tight or slightly too loose... Maybe there's a sweet spot that works on some bikes, but I have enough trouble getting that balance right with the full range of motion that I doubt they would ever work well for me.
True, because the easy-pull devices have reduced travel, you gotta make adjustment perfect. But once it's done, then it's perfect, AND easy!
Old 07-12-2019, 08:49 PM
Architect's Avatar
Architect
Architect is offline
Received 4,873 Likes on 2,540 Posts
Have you called Baker and talked to them? I hear their customer service is excellent, Mark from Baker is also on this site, maybe look him up. I wish I had a solution for you, good luck.
Old 07-12-2019, 09:14 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,779 Likes on 17,441 Posts
While Baker is still a sponsor Mark has moved on to other things.
Old 07-12-2019, 10:20 PM
F86's Avatar
F86
F86 is offline
Sorry to hear that! His two cents was always valuable, whenever he chimed in about anything!
Old 07-13-2019, 08:45 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is online now
Received 4,281 Likes on 2,349 Posts
Here's a stupid question. How much oil in the transmission when all these parts are welding to each other. Qty. is 20-24 Ozs.
Old 07-14-2019, 07:17 PM
John CC's Avatar
John CC
John CC is offline
Or could it be the primary? Either way, I can't see how this is happening, apparently in minutes, to parts that are practically immersed in oil. Heck, I've seen engines go close to 12 miles with no oil.
Old 07-14-2019, 09:12 PM
TwiZted Biker
Those tiny TO bearing are not designed for constant loading like when someone adjusts the cable out trying to cure a grabby or dragging clutch, they will fry in an oil bath.
Old 07-15-2019, 03:06 PM
John CC's Avatar
John CC
John CC is offline
I know guys who will hold the clutch lever in for 2-3 minutes waiting for a single lane construction site. Never heard of a failed throwout bearing... Just saying...
Old 07-15-2019, 06:33 PM
TwiZted Biker
You aren't a bike mechanic, I am so the experience pool is a bit deeper on my end. Just saying ...
Old 07-15-2019, 07:14 PM
John CC's Avatar
John CC
John CC is offline
If you mean I don't work at it 40 hours a week, you're right, but, I am a mechanic, and at my age there's a chance I still have at least as much experience as you do. Just saying. Then, there's all those TO bearing failures from sitting in gear waiting for the traffic light to change...
Originally Posted by JrMizzi
Literally started the bike in Neutral, depressed the clutch which felt great and put the bike into first and back to neutral about three times. Didn't even drive it. Let it cool over night and pulled apart. I can already see heat Mark's on either end of the push rod and the washers on either side of the throe out bearing are already looking heated and warped.
Sorry, but I'd look elsewhere if it shows signs of overheating after that.
Quick Reply: End of my rope ~ 02 Dyna With Baker Kicker
