End of my rope ~ 02 Dyna With Baker Kicker
If you mean I don't work at it 40 hours a week, you're right, but, I am a mechanic, and at my age there's a chance I still have at least as much experience as you do. Just saying. Then, there's all those TO bearing failures from sitting in gear waiting for the traffic light to change...
Sorry, but I'd look elsewhere if it shows signs of overheating after that.
I'm not saying what you describe isn't possible, just that I don't see how it fits this guy's situation.
OK, but how could he be shifting in and out of neutral and first if it was set that tight? Maybe I am missing what you're saying, but if it was that tight wouldn't it be impossible to squeeze the clutch lever, or at least impossible to engage the clutch and get first? He said after the first replacement he was able to drive it, so how could it be that far out of adjustment?
Thing is there is no other reason that bearing will burn up unless somebody forgot to put the bearing wafer in between the hard washers for some reason, that's it. Once the bearing starts seizing it spins the whole push rod assembly and galls the end in the clutch pack too.
Noticed your bike list I had several BSA’s wish I still owned. Had a 68 Firebird scrambler an old flat track racer rebuilt for me in 1973, poked it out 720 welded and ground a cam for it , thing was beast.
Yeah, the BSA's a project. Hasn't run in over 20 years. I'm afraid to do anything to it without first cleaning out the crank. I'm sure it's full of dried sludge. Matching numbers. The T150 would run if I just put the head back on. The T900 needs swing arm and rear suspension and would be good to go... I just don't get things done as fast as I used to.
Well just since I mentioned it here, I did replace the clutch cable and left in the Easy Pull and things are much better. I do have a very slight amount of clutch drag but I have more range of clutch pull, I can now shift easier, find neutral while running, and back the bike with the clutch in. The clutch movement is also much smoother with the Barnett Chromite II cable I put on so if that helps any.
