Need a new rear tire
2013 Dyna Switchback. Rear tire just about worn out. Original tire is a Dunlop D401 160/70B17. I can buy a new Metzeler RoadtecZ6 160/70ZR17 cheap. I know this is a Radial. Front tire is still the original Dunlop D402F Bias.
Can you guy see an issue using Radial on the back and Bias on the front??? Thanks for your help.
If your still on the original tires...you have a lot of things to do. most maintenance items have a time limit to them, so regardless of mileage your going to want to do a few things immediately....
Brake Fluid change it
wheel bearings front and back change them
front motor mount change it (do not use stock)
powertrain alignment do it
you can do these things while your getting your tires changed. I personally recommend a matched pair, front and rear....tire and bike manufacturers tend to know what they are doing so I listen to them....
Prodigal_Sun (07-15-2019)
raaaaaa
05-11-2007 08:55 PM
