09 street glide starts by turning key on
Old 07-11-2019, 02:27 PM
sportsterjohn's Avatar
sportsterjohn
sportsterjohn is offline
Stage II
Unhappy 09 street glide starts by turning key on
I need some help here.Last week after about a 2 hour ride, I pulled into a gas station and I could hear gears meshing. Not too loud but I did not like the sound of it at all. When I started it the other day it made the meshing noise so I shut it for a couple of minutes and when I went to started it again, it started as soon as I turned the key. I never touched the start switch but it started. I pulled it around to the front of the house and shut it off for about a half an hour and when I restarted it ,it was normal so I shut it off and back on and it started with the key. Anyway I switched out the starter relay and the brake relay with no different results. Has anyone else ever had this problem and if so , how do you fix it and is it possible to be the starter clutch ?Thanks
Last edited by sportsterjohn; 07-11-2019 at 03:59 PM. Reason: after further reading about the starter clutch
Old 07-12-2019, 12:05 PM
nevil's Avatar
nevil
nevil is offline
You might want to post in the Touring section, your bike is not a Dyna. Some things are common but not necessarily so.
I would look at the starter switch wiring first.
sportsterjohn
07-12-2019 05:46 PM
xjjeep96
General Topics/Tech Tips
06-22-2017 04:37 AM
h-d wrencher
Engine Mechanical Topics
09-18-2016 10:39 AM
Judge1989
05-22-2013 12:09 AM
NewAge
06-28-2010 09:12 PM
Quick Reply: 09 street glide starts by turning key on
