Oil related.... FILTER issue
Anyone ever have a filter issue where it caused the bike to knock? Got the filter from a dealer in Columbia and it is going back there too! Replaced that filter with a drag speciality filter and noise stopped.
I was thinking oil pump, top end replace or replace motor... Glad I didn't over re act....
Man it was a rough day.. Almost had to use my AK..
Ain't there a filter bypass? In the event of a clogged filter your bike will still get oil...dirty but better than nothing. I might be confused on bikes tho. What if u have a weak oil pump and a malfunctioning bypass and an oil filter that filters finer particles? What kind of filter did u have to begin with? Microns? .....no expert btw...and can't say I believe what I'm saying....just talking
I agree, it doesn't make a lot of sense. Usually, the first thing to knock due to oil starvation is the rod bearings, unless you have hydraulic lifters.
If the filter was plugged it should have gone into bypass. Not all filters have a bypass valve, but those that don't should be paired with an engine that has its own bypass valve external to the filter. If it is the right filter there should be no problem.
If the filter was plugged and there was no bypass, I'd expect the filter can to burst.
The only way I can see that happening is if the outlet was 100% blocked. Should be easy to figure out if you cut the filter open.
How long did you run it like that? Did the oil light go out? (Are you sure it was the top end that was knocking?)
[Edit]Oh, I see, you didn't say the top end was knocking... You may want to do an oil analysis if you still have the oil that was in it when it was knocking.
