What is the torque specification for the shift lever pinch bolt?
What is the torque specification for the shift lever pinch bolt? I cant seem to find it in the manual. 2006 FXDB
Thanks! |
id say not much
Originally Posted by Studlintsean
(Post 18395864)
Agree. |
You got 2 choices.
Tighten it til it starts to strip and back off 1/8 turn.. Do them by feel. Locktite the thread and molly grease under the head. Tighten until you feel it get snug then continue until it gets tighter a second time then stop. I prefer the second method. |
(Post 18397686)
You got 2 choices.
Tighten it til it starts to strip and back off 1/8 turn.. Do them by feel. Locktite the thread and molly grease under the head. Tighten until you feel it get snug then continue until it gets tighter a second time then stop. I prefer the second method. https://cimg8.ibsrv.net/gimg/www.hdf...8f0fd2231.jpeg https://cimg0.ibsrv.net/gimg/www.hdf...5880f1b6e.jpeg |
Anything past oil plug tight requires experience. I snug everything then snug it again....a system taught to me by my Dad a diesel mechanic.,
(Post 18397686)
You got 2 choices.
Tighten it til it starts to strip and back off 1/8 turn.. Do them by feel. Locktite the thread and molly grease under the head. Tighten until you feel it get snug then continue until it gets tighter a second time then stop. I prefer the second method. Max is on point here. I go a bit farther.... use a grade 8 cap screw with a smooth flat washer underneath, along with the lube :icon_beerchug: __________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters |
One of the thing most miss, is that if it's allowed to run loose for any period of time, it will require a couple/ few re-tightens before it will stay tight. The only reason why it's a weak point is due to failure of proper maintenance. This is not confined to HD. Any bike that uses a splined shaft and clamp to hold in place an arm be it a shift lever, clutch arm, etc can have this issue. I've seen the problem on a number of different motorcycles.
(Post 18398307)
© 2024 MH Sub I, LLC dba Internet Brands
