Is it worth going to gear drive? I have heard so many different opinions now I'm confused. What are the pros and cons of doing such a thing.
Is the performance gain worth it?
Unless you change the grind of the cam, I can't imagine that there would be any "performance" change. I think the main reason for doing this is to eliminate any risk of the standard cam chain tensioners failing.
I had gear drive on my last cam TW31G on my 95" WG3. In terms of performance gain , you may pick up a small amount due to increased mechanical efficiency. The real advantage is peace of mind on the <07 motors when it comes to the earlier cam chain tensioner issue .
On my 07, I went with a chain drive for now , the new roller chain cams are supposed to have addressed that issue. Time will tell.
Thanks, I was thinking of going withAndrew CAMS 37. Is this a wise choice?
I have heard that the the 06 and later chain drive is alot better than the earlier models.
I have an 05, so I converted to Gear Drive cams. I love the seat up, its simple and reliable! I bought the S&S kit, then I had to choose cams.
I have heard alot of good things about the Andrews 37s. I bought some a year ago, but sold them and went with Head-Quarters cams instead.These cams have a broader power band than most other brands. HQ has a very good bolt in cam called the 0034 cam.
I talked to a guy that runs the Andrews 37 and he said it runs great and has loads of torque!
I have also heard that this cam is sensitve to compresion that is more that 9.6 to 1 and to run it well, one would have to have a way to pull some timing out to remove the risk of pinging.
Thanks for the input. My first concern is peace of mine, the added performance is a plus. I would pay a little more for the performance since I will be doing it any ways.
Thats what I was thinking as well, tear it apart once and get it all done at once. Would like to do the heads as well but a little to costly and really dont need it at this time.
