Street Bob forward control question
You don't have to. When I installed the FLD kit on my 2012 Super Glide which had mids I left the shaft in and zip tied the inner shift lever down at about 90 degrees where it couldn't move around The forwards come with a longer linkage so you get rid of your original linkage. The shaft coming through the primary you can buy a cap from ebay or any of the parts suppliers to cover it in chrome or black. If you decide to go back to mids everything is still there. Not that hard.
I recently bought a 2016 Low Rider... I have a couple softails and a bagger. I hadn't dealt with mid controls since my 1980 FXS....
I searched for 8+ months trying to find the best bike, deal for me...
I was surprised to find that in all that time and looking at all those Dynas, that of the bikes with mid controls switched to forward controls, the vast majority left the shaft in place through the primary. They just put a cap on the shifter mount on the outside of the primary, leaving the shifter lever in between the inner primary and the engine case...
The first couple I saw like that, I just figured it was a short cut taken by some who were too cheap and/or lazy to "do it right".... Then an independent motorcycle shop told me that many people do that on purpose, so they can/could convert back to mid controls if they wanted to...
After seeing how many chose to do it that way, I figured there must be more to leaving it than just being lazy... After reading the Dyna section here for the last couple of months, I can see many threads about switching back to mids... so the switching back & forth is done more than I would have guessed...
IMHO.....
Leaving the shaft in place shouldn't affect anything in the primary, or the shifting...... The shaft just passes through the primary cases...
Unless the the shift lever between the inner primary and engine case is interfering with the forward controls new shift linkage, I don't see how leaving it in place it could affect shifting..
I would suspect any sudden difficulty with finding neutral would have something to do with the new linkage...
