Stiff clutch
Old Jun 27, 2025 | 07:38 PM
hogster1961's Avatar
hogster1961
Default Stiff clutch
My 96 low miles dyna has been laid up since last september, while it's been off the road l've changed the bars, l reinstalled the original clutch cable tonight but it feels excessively stiff, the bike's not running atm pending a new carb so l'm not able to fully test it although pushing it about in my garage in gear it doesn't seem to be fully disengaging, with the clutch pulled in l can move it with the lever back to the bars but only just....is there something l'm missing or should be checking....l also have a couple of other newer bikes(HD) but their clutches are a lot easier.
Old Jun 27, 2025 | 08:40 PM
benscratchin's Avatar
benscratchin
Question
Did you follow the Service Manual procedure for adjusting the clutch cable?
Old Jun 27, 2025 | 09:15 PM
hogster1961
I haven't needed to adjust the clutch it hasn't been disconnected...l only removed the lever from the old bars.
Old Jun 27, 2025 | 10:28 PM
Max Headflow's Avatar
Max Headflow
Put it neutral when you push it around.
Old Jun 28, 2025 | 04:48 AM
eighteight's Avatar
eighteight
Lube the cable.
Old Jun 28, 2025 | 06:03 AM
Bubba Zanetti's Avatar
Bubba Zanetti
If you went to taller bars or rerouted the cable, it may need an adjustment.
Or it may need a little lube if it’s sat for a long time.
Old Jun 28, 2025 | 07:48 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Because it's been sitting for a long period, the disc's are probably a little dry.. Get it running and take it for a ride then check it..
Old Jun 28, 2025 | 08:20 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Is the cable plastic lined? Is the any curves nice and smooth not tight turns?
Plastic lined cables don't need lube they need to be cleaned. I injected methylated spirits through mine and it made really smooth. I put a dab of grease at the top to stop water going in.
Old Jun 28, 2025 | 08:50 AM
union53's Avatar
union53
This would be my first guess. Had this happen to bikes in the past. Clutch plates can stick together if it sits for a long time. Taking it for a ride usually clears this up but be a bit cautious. The bike might lurch forward when put into gear.
Old Jun 28, 2025 | 12:15 PM
08xl1200r's Avatar
08xl1200r
Lube the cable.
+1, it took me 3 tries to get in right on my '98 but the clutch is now smooth with a relatively light pull and that has lasted for over a year so far. FWIW I used Dupont spray teflon lube...
