FXDWG triple trees with 0 rake options...
Fits:
1988-Up FXR
1991-2017 FXD
1988-2022 Sportsters with 39mm front ends
Ideal for Flat Track Racing, Reduces Neck rake by 3 Degrees for quicker steering.
Note: This will raise your fork tubes by about 11/16" (lower the front end).
Machined from High Carbon Steel & Bright Nickel Plated for Corrosion Resistance
Bottom bearing cup has a fork stop lug.
Retains internal fork lock & tapered bearings.
ATTN DYNA WIDE GLIDES: If you are swapping the front end to a 39mm use the Sportster kit that matches the trees not the dyna wide glide kit.
Set includes: Raked fork cups, Neck Bearings, and a new Fork stem
Fits:
1988-Up FXR
1991-2017 FXD
Thanks for the suggestion, I was considering raked cups at one moment, but that does very little for the overall stability. The main goal is to get the most optimal geometry, but cups... They will just reduce the angle of the neck, in a good manner, but there's still a different angle between the stem and tubes, and thats the main thing I'd like to get rid off. My currently most acceptable compromise would be FXDF trees, with -1 degree, if I fail to find 0 degree trees....
