2008 fatbob engine light Speedo issue
Old Oct 8, 2025 | 07:59 AM
scott77nightster's Avatar
scott77nightster
Default 2008 fatbob engine light Speedo issue
Hello, thank you ahead of time for any insights or points in the right direction. My 08 fatbob will start fine than the engine light will come on, then go off, but when it goes off the light for the speedometer goes out with it. It will also start to idle a little high at this time. I’ll drive it a bit and the engine light and speedometer both come back on, but at this time the idle is fine. Thinking a loose wire, already tightened battery cables. Working on reading the codes. Just thought I’d put this here in hopes of someone maybe having a similar experience. It has about 25k miles. I’ve only owned it a year? But this is the first issue. Thanks again.
Old Oct 8, 2025 | 11:33 AM
nevil's Avatar
nevil
Did you check both ends of both cables, or just at the battery?
Old Oct 8, 2025 | 02:50 PM
scott77nightster
yes. Seemed secure.
Old Oct 8, 2025 | 03:24 PM
Addicted to Chaos's Avatar
Addicted to Chaos
Engine runs fine?
Old Oct 8, 2025 | 07:37 PM
Suede Blue Man's Avatar
Suede Blue Man
Codes; what code clues have you come up with?
Old Oct 9, 2025 | 03:35 AM
Bass-M's Avatar
Bass-M
That sounds like a classic bad ground connection. The engine light, speedo, and idle are all linked to the same ECU.
Check the main ground wire from the battery to the frame and engine. Clean the connection points until they're shiny metal. Also check the ground connections under the seat and on the front of the engine.
A loose ground causes all those weird, linked electrical gremlins.
Old Oct 9, 2025 | 05:25 AM
scott77nightster
Thanks for replying. Codes pointing to a regulator I think. I’m going to throw a regulator on as it would race up to 17-18V. I will also trace down grounds.
Old Oct 9, 2025 | 05:28 AM
touchdown's Avatar
touchdown
That light is also a warning light for your tail and turn signal, and stop lights. On my bike it just stayed on and I found a bad light bulb and it went when I replaced it. So just a shot in the dark maybe a bad bulb or loose one.
Old Oct 9, 2025 | 07:42 AM
Bubba Zanetti's Avatar
Bubba Zanetti
If it were the voltage regulator wouldn't you see the engine light and the battery light instead of the speedo light?
Old Oct 10, 2025 | 07:37 PM
Suede Blue Man
I think OP is talking about the orangish light shaped like an auto engine that can come on with engine problems, are you talking about the little red light to the right of center (at least on mine)?
Now that light does come on with a brake-light problem.
