* HOW TO * under fifty bux *
#2193
How to install fork gators so water will not get in.
1- use the right size paint can plastic lid. Drill a hole thru the top with a hole saw. Silicon this to the fork slider indent where the chrome cap rests.
2- zip tie the fork boot to the paint can lid at the base and the fork tubes on top
ABQ-Jammer (01-24-2019)
#2194
License plate bracket mod.
Young son wanted a laydown bracket, but had a zero budget to work with.
So, he simply removed the rear stiffener and reflector, pushed the rest of the holder over, and accidentally trapped the phillips screws. We eyeballed the screw locations, started with a pilot drill and worked up to the screw head size to get them out and make it serviceable. Lighting was accomplished with these ebay license plate LED bolts wired to the empty socket inside the taillight normally reserved for the FL style rear fender red tip light. Vibration worries shouldn't be an issue with the cast metal Emgo frame around the plate that also covers the new mount screw access holes. I blacked out the top of the tail light with some flat black vinyl, but I think the bottom needs to be done also. When I do my Low Rider, I'll tape off the rear lens and mist some black inside to reduce the red edges seen from the outside. Total investment = $15.
Sorry for the big pics, I don't know how to shrink them from saved album pics.
No radio required or desired.
2004 883 cleaned, serviced, lightly modified to taste and ready to ride, spring 2018. It's a great machine.
#2196
#2197
Well I don't have an 883. My Super Glide has touring shocks and I love them, super comfy. 6'1" 240 makes "super comfy" difficult sometimes.
#2198
#2199
#2200
Bartenders Friend Powder
I had been getting grief about the state of my pipes for ages, and, like you say, all the usual products are all properly expensive - I had never heard of this stuff before and thought that it was an American thing, but found it by chance in my local Pound World.
Don't know what is in it or how it works, but it does, and now my pipes are gleaming again. 10/10 would recomend
No pics I'm afraid, as this is a shameless attempt to get my post count up so I can post pics somewhere else . . . . .
