* HOW TO * under fifty bux *
#501
RE: HOW TO - under fifty bux
ORIGINAL: mudpuddle
Here’s a good tank beatin for ya.
First picture below, I have welded quarter inch round stock
to each side of the tank to lock in the perimeter shape.
Then I drew a line where the deepest part will be when finished.
In the red outline is the tool I fabricated for the beating.
About six inchs long by one and a half by two inches.
Shaped at the end as you see on the left.
The orange clamps are holding the tank fixture
to the table to eliminate moving all over the place.
Started beating along the green line, little by little,
working outward as the depression gets deeper.
Next, below, beaten all the way in.
Also you see the rib I welded down the center,
with the nut welded for the shortened console attachment.
Shown below, the fuel injected machines fuel pump
is only one and a quarter inch away from the tank side.
So before I started beating, the original tank profile
is cut into a wooden template for gauging depth of the new cavity.
The gauge mounts to the tank holding fixture
the same on both sides.
I used a filler called All Metal, similar to Bondo,
it is an aluminum powder type formulation.
Saw Indian Larry do it on TV once ... thought it was great!
Your beating aparatus ... A block of wood?
You do the beating with the shaped edge on the left?
Are you using it like a chisel? In combination with the wooden mallet shown.
Never woulda thought it was beat in that manner.
Very cool ... very custom!
Ray.
#503
#504
ORIGINAL: RonnR
Mud,
sorry it took so long to do this, but as per your request, theres the
details.........
My cost was over $50.oo, but only my a little(mainly because of themis-
Mud,
details.........
Real good one.
Cost for do it yourself to start from scratch would probably be $25-30 bux.
You and RudeDog did a good job on it.
mud
#505
#506
ORIGINAL: UPHEVIL
dude love the no plug for the trim ring i wont tell .... but i was thinking you should wrap it in leather.... or if you acumilate (yeah what ever) enough car part you can have a hot rod....just kiddin get back to work
#507
Good questions Ray, thanks.
Here are some better pix of the beat tool.
I like wood for this type of beating. White Pine in this case.
First picture below shows both ends, which are shaped slightly different,
and a leather mallet.
This next picture shows the narrow end.
Note that the "narrow"surface is also slightly rounded.
The edges that run the length are eased,
so you can hang on to the apparatus comfortably
during a lengthy beating.
The "narrow" surface was used first along the green horizontal line.
Love taps at first, progressing to a more violent striking action
as the operation proceeds.
The other end is about twice as wide.
I used this after the green line was punched in about a half inch
Work outward progressively from the green line.
You cannot jump around from here to there.
You're question about "like a chisel" -
Don't quite follow you, but. I think the answer is no.
The instrument is struck in a "straight on" manner.
Then the AllMetal.
ORIGINAL: RazorFXDB
Thx for this contribution Mud. Been waiting to see it for a while.
Your beating apparatus ... A block of wood?
Ray.
ORIGINAL: mudpuddle.
Ray.
Then the AllMetal.
#508
Mud, great job putting together the index. Last week I put together my Ooga Booga A/C cover bolt and today I made my bullet key. For my key I had a buddy make me a dummy round, he gave me a S&W 500 MAG. I don't know much about guns and ammo but thats one big pistol round. I'll try to get some pics. up this weekend.
#509
ORIGINAL: metal_mike
my 1st language is english....but youre gonna have to translate that one.... i got nothin'
ORIGINAL: UPHEVIL
mike, you musta missed the part where HEVIL said "just kiddin".
mud
#510
ORIGINAL: HDDyna2006
To dress up those rusty exhaust clamp screws,
and any other rusty screws, allen wrench holes, etc.
Get some testor model paint from your hobby shop,
and with a q-tip apply and let dry.
I'll add that into the index soon.
My main memories of Testors,
are the glue in the orange tube.
That **** would send ya around the world,
and climbing walls while sitting in a chair.
mud
