side mount license plate wiring
I have '06 Dyna Street Bob. I boughta dreamweavers' vintage side mount license plate. It is a model A light. Their site is www.dreamweaversprostreet.com
Anyway, the license plate has 2 wires, whichhas ablack (ground) andthe other isgreen. I am not sure. The plate light has 2 bulbs: one is forrunning and brake n the other is located on the bottom, that is forthe license plate. So my question is whichwire should the green wireconnect to? Thanks, Chris |
RE: side mount license plate wiring
There is no ground......... . .or should I say....it grounds itself..to the swingarm.....I dont remember which one was for what..........but I do remember that When I hooked it up..I had it backwards..............The not so bright is running light....and the bright is brake............. If you switch them.......Bright as running it gets to hot and will burn the socket.....I know from experience............. . .so hook'em up.....or do a test before you get fancy with youre wiring to make sure its right.................Hope this helps.............or makes sense........If not pm me and I'll walk you through it................................................ ............. . . . .............
what he sais i have the some one
cool nice plate and thanks for the link
i see, there are 3 wires in the harley - black, purple, blue. I'm guessing the green wire is the running light? and the black is the braking? the whole plate is ground when attached to the swing arm. I'd like wire diagram for better clarification. I'm kinda confused with the ur description. Sorry, I am still learning.
get a car battery and place the bracket on the negative and then touch one wire to the positive side to see what it does.....its easy man......bolt it on and wire it
i already put the bracket on the axle. i hooked the black wire to the black wire that goes to the stock tail light under the seat. then hooked thegreen to the blue wire. The lights works, but when i hit the brake, it doesnt work, it just stays on while the bottom light is out. so lolife mention that the black wire isnt ground, it could beeither connect to the blue or purple wire. I just dont want to cut up so many wires under the seat.
yeah dude just leave the black on alone man its already grounded ..... what light turns on the bottom one or top??
top works, not the bottom, what did u hook the black and green wire to?
the black wire doesnt go on the black wire bro......connect it to the other one........and your done
© 2024 MH Sub I, LLC dba Internet Brands
