HDI World pls help this out !!!
RE: HDI World pls help this out !!!
hi again
I got some news about the issue. I went to dealer today. we took off front o2 sensor from a street bob 07 model and installed mine. happy to say no error codes of p0134. as I did not install rear o2 sensor po154 code still remains. we just tried and it worked. so I will order both front and rear o2 sensors . part no 29683-06 is same for front and rear. after adding o2 I hope there wont be codes anymore.
only question is I see few posts talking about o2 eliminators. I do not know what is this for. any comments appreciated
Location: Back in the Good Ole USA. South Carolina to be exact.
If I am not mistaken the PCIII does not use O2 sensors and comes with some sort of O2 eliminators. The Power commander might be the low budget fix for your problem.
Seems like the error codes are more of an annoyance than a real problem. You are only getting them because there are no O2 sensors, not because of an actual \\;lean condition. Seems like you could just ignore the codes in this case.
I am running XIEDs, J.E.T. Phase 2 AC, and mufflers w/drilled baffles. Every now and again I get the P0134 and the P0154. I can't detect any excessive leanness in the way the bike runs.
Sorry if I bother you but please tell me which of the options I should proceed
1) \\; installing o2 sensors ? \\; \\; (because front o2 sensor error code stopped when I installed. and rear code still comes up as I did not install o2 sensor in the back)
2) or instead of buying o2 sensors should I buy pcIII as they come with eliminators ? in this case, why I need to eliminate o2's if they are working properly. Do you think that I will get the codes even if I install o2 sensors ?
buying o2's are only usd usd 100 ( usd 50 per each ) .I do not know how much is the pcIII ?
Riding in istanbul is like you ride in a circus. there are 15 million people in this city \\;and we have God damn traffic problem. In any case I drive just for pleasure on weekends. and ride to work daily....
thank you very much indeed for those replying to my post
ORIGINAL: kuleli
1) \\;\\\\\\; installing o2 sensors ? \\;\\\\\\; \\;\\\\\\; (because front o2 sensor error code stopped when I installed. and rear code still comes up as I did not install o2 sensor in the back)
Riding in istanbul is like you ride in a circus. there are 15 million people in this city \\;\\\\\\;and we have God damn traffic problem. In any case I drive just for pleasure on weekends. and ride to work daily....
 \\; The PCIII is around $250-$300 US. Which gives you a fuel management system that is a open loop system. Many online maps that would work like a downloaded map from HD.
 \\; The PCIII O2 eliminators are a pair of resistors. Maybe some one would be willing to measure there resistance so you could make your own. I want to say 330 ohm resistors jumping the O2 sensor wiring would work. 330 ohm resistors are roughly $1 US each but I am not certain 330 ohms is correct. What you would be after is the 1 volt signal voltage sent from the ECM to be .45 volt back. This would get your HD download to work without buying a PCIII or the O2 sensors and may cost as little as $2 dollars US.
man4mopar
so If I install o2 sensors then error codes disappear. This is the main issue for me.
Then if I do not want to put resistor and use the bike as closed loop what makes the difference ? will the bike run lean or not performing well etc...
kuleli
07-01-2008 02:41 AM
