Power Commander information
Would I gain anything by installing a power commander on a stock 06 Street Bob? \\; I mainly want to smooth out the ride and thought by getting the engine to run smoother, it would lessen the buzz. \\; Has anyone put this on a stock machine? \\; I have checked everything that has to do with vibration on this site and everything checks out OK \\;on my bike (no broken mounts, no gap in mounts at front, no \\;loose fasteners, everything is in \\;alignment). \\; Darn thing is driving me nuts.  \\;The typical harley vibes are one thing but the buzz is \\;not cool. \\;
RE: Power Commander information
Contact the folks at Power Commander. You can send a question through their site - they are great about responding. \\;
What the heck is "buzz"? \\; I put a PCIII on mine just to be able to richen up the fuel mixture. \\; Remember......14:7 is pretty lean.
nightprowler's Xied's richen your mix from 14:7 to 13:8 and it's only 100 $$,takes abot ten minutes to install! maybe off topic here.
the DynoJet guys will tell you that the PCIII will benefit a stock bike - it should run cooler with a richer mix.
as far as the "buzz" goes, a richer mix will not change the vibration. |
If you decide to get a PCIII, call Jamie at Fuel Moto. www.fuelmotousa.com They send you the unit already programmed for your application and give you an extra year of warranty, plus free map updates if you make any changes. Sorry to sound like an infomercial, I'm just a satisfied customer. I didn't have any buzzing on my bike (just normal HD vibes), but the PCIII did seem to smoothe out the power delivery.
I did my 1000mile service and dyno run and I think my bike run a lot smoother
after the dyno.Less vibration in low and mid rpm than before the dynorun. I got max 73.6 hp and 118,5 n-m torque on the rear wheel. Rush slip ons,PCIII and SE airfilter. |
© 2024 MH Sub I, LLC dba Internet Brands
