103 stage 2 starting map SERT
Anyone have a idea on starting map for a 103 stage 2(255 cams),SE 50mm TB assy,This map iv heard with the 110 VE map runs godd. Any help is great.OH this is for the breakin then resert and dyno with cam (GD).crank welded and timkins installed,stock heads with SE spring and adj push rods also install.Also does the california smog retard cam timing like a car?Would any one advance the cam?
© 2024 MH Sub I, LLC dba Internet Brands
