Who's sick of harley throttle? i found a quick turn throttle
However I still don't see the advantage. I went out a measured my throttle travel at the grip 'cause I was curious.... what do you know, 1/4 turn. The point on my grip that was facing forward, was facing straight up at full throttle. I have HD-X2 grips, but they are not advertised as a "reduced travel" grips.
I would be curious as to what other riders get here, when you measure your grip rotation???
I like these. If you grab your throttle in a natural position and then to go full throttle your wrist is bent downward and your hand bent backwards. These throttle tubes have a bigger diameter where the cable rides (hence the throttle lock won't clear). This bigger diameter reduced the full turn to full throttle from 90 degrees to about 75 degrees. You can purchase them from Avon directly with any of there grips already installed.
Haha, call me Doctor.. Doctor Frankenstein!!!
How about these? https://www.motionpro.com/featured/rev2_throttle
Just came across them and thought it was a brilliant idea.
Also, The Victory guys are running something called "Lloyds Throttle Ring"... before stumbling across that, I had thought about making something very similar that would work with the stock housing in order to avoid a new throttle housing and the mess of conversion nonsense that would follow. Any reason why I cant make one and try it?
