help, rear wheel install
Old Apr 18, 2005 | 09:18 PM
98fxd's Avatar
98fxd
Default help, rear wheel install
sorry for the double post guys, posted in tech but thought the dyna guys might be able to help me out... need a quick response.
re: 98 FXD.
just had a new tire put on and i reinstalled the rear wheel on the bike today. i understand the rear axle should have a torque of 55 to 65 ft lbs (per local dealer). i don't have a torque wrench and my neighbor, with the same bike, said to "just crank it down". should i get the torque wrench? is there a bearing load index that needs to be accounted for? will i freeze up my wheel or damage my bearing by over torquing?
thanks a lot
dan
Old Apr 18, 2005 | 10:43 PM
DGlide04's Avatar
DGlide04
Default RE: help, rear wheel install
That's exactly the reason for having the proper tools. Factory sets the torque specs to avoid the axle being too tight and possibly overheating the bearings. Not something that you want to happen. My advice, buy, rent or borrow a good torque wrench. I went through the same thing two weeks ago with my '04 FXD, I bought a Craftsman at Sears for about $79.00 on sale, the click type. You'll use it and it will pay for itself in no stripped bolts, etc.
Old Apr 20, 2005 | 01:59 AM
98fxd's Avatar
98fxd
oh, i have one, or had one. seems to have found a new home somewhere. i will check it tomorrow.
thanks
Old Apr 26, 2005 | 01:45 AM
billnourse's Avatar
billnourse
98FXD,
If you don't have the sealed bearings, make sure that you have the proper axle end play. This will require a dial indicator with a magnetic base. The end play should be between .002 and .006. The proper torque is also essential.
regards,
Bill
Old Apr 26, 2005 | 03:49 PM
Dyna Fitz's Avatar
Dyna Fitz
Your local Auto Zone will let you borrow a torque wrench. Will probably require a deposit.
Old Apr 26, 2005 | 07:52 PM
98fxd's Avatar
98fxd
found my torque wrench! it was hiding. thanks guys! i also bought a manual
GrovenSportster
Aug 28, 2011 10:10 PM
Billydj
Aug 18, 2011 10:31 AM
Fastfwd
Sep 23, 2010 11:56 AM
frankharley07
May 9, 2008 01:40 PM
98fxd
General Topics/Tech Tips
Apr 21, 2005 12:15 PM
