tire lifespan
Old May 18, 2009 | 09:13 AM
archergodwin's Avatar
archergodwin
I check it more than once a week. I sure don't plan on using Dunlops next time around.... I'll boost the pressure then. As far as roads.... all I have around me are country roads
Old May 18, 2009 | 09:20 AM
dyna07custom's Avatar
dyna07custom
got 10k out of rear still running front i run about 60/40 2 up
Old May 18, 2009 | 10:53 AM
pugs's Avatar
pugs
If the dunlops are not as good, what do people recommend as a better set of tires?
Old May 18, 2009 | 11:02 AM
SC-Longhair's Avatar
SC-Longhair
How do you mean 'better'? If you want performance such as better grip, get a softer tire like Metzeler or Avon. Softer tire will wear out faster but something was seriously wrong that you only got 5k miles out of your rear tire.
Old May 18, 2009 | 12:41 PM
mtnlvr's Avatar
mtnlvr
There's nothing wrong with Dunlops, but some models don't fair as well as others. I've got over 13K miles and a half dozen burnouts on a rear Dunlop which I'll replace with another Dunlop fairly soon. Not a stock Dunlop, but and Elite 3.
Old May 18, 2009 | 12:57 PM
pugs's Avatar
pugs
I never really had any performance complaints, just was surprised that the tire didn't last longer, especially since I am a pretty conservative rider.
Old May 18, 2009 | 03:12 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Younger bro ('04 Wide) got 18K out of his stock front, but you could see the air! I just replaced mine a month ago with Michelins (Macadam/Commander, R/F) at 11K. When I picked up my bike from its 1000-mi checkup, the service writer told me my front was 4/32" and they recommend replacing @ 3/32"...I looked at him and said, "You realize I'm in here for my ONE-thousand mile checkup?!?!" He looked away and quickly went on to the next item. Went home and to the Dunlop website...they START life with 5/32", and the dealer wants you to chuck 60% of your treadlife?!?!
Old May 18, 2009 | 03:30 PM
PigInaBlanket's Avatar
PigInaBlanket
I had the stock tires changed out at 12,484 miles. The rear needed changed, the front could have went farther but I went ahead and replaced both at the same time with Dunlops again. I like the Dunlops.
Originally Posted by HarleyGoodies
I run brands other than stock and go by what it says on the sidewall.
Some other tires do have different air pressure reccomendations I have heard but from my understanding whatever is on the sidewall is the max pressure that tire can take. I would find out what the recommended pressure is and not go off the sidewall. They recommend a certain pressure for different vehicles for a reason. Overinflating tires can make the middle of the tread wear out quicker and could be dangerous if inflated way too high.
I personally go from what HD recommends for my bike and run the front at 30 and the rear at 36
Old May 18, 2009 | 04:19 PM
rounder's Avatar
rounder
I run my metzelers at 30 front and 36 rear... For the 1st 1K on them I had them at sidewall pressure(42 rear 40 front)... Sure I might get a touch more life on them by over inflating, however the ride quality and way they stick like glue around corners convinced me to run at H-D recommended pressure. Way better to run at the bikes recommended pressure and not the sidewalls. If you read the stock dunlop sidewall, it has max pressure at 41 which is about same as metzler sidewall. Note recommended pressure is for a 170 lb rider riding solo... bump it up a couple psi if you are over 200+ otherwise your weight will wear the tires more quickly. Also it is recommended to run the rear with 3psi more when 2up. Get a good accurate air gauge. H-D sells a nice one complete with a tire wear indicator.
Old May 18, 2009 | 04:42 PM
SBRob's Avatar
SBRob
Tire wear sure does vary alot...I'm at 4470 miles with the OEM tires and I "might" get to 6500 for the rear, but the front tire is fine. I always check tire pressures every 4-5 days and run 30/37 cold psi riding solo.
I like the feel and handling with the Dunlops, so I'm gonna get the SE 180 rear when it's time to change and "hope" to get 5K out of it.
