How -to: Epoxy paint lower legs
I keep getting PM's about how to do this so i figure this would help everyone... (thanks to Special ed for showing me this a few years ago)
Painting lower legs with epoxy paint...
-First remove tires and caliper(s)...
-i then sand down with 220 grit sand paper... you need to get through the clear coat that is on most lowers (aircraft stripper will do that as well) then get a good profile on it with 400 grit....
-after you have a nice profile, use 1 light coat and give it 5 min to tack up... then hit another coat, keep this process up to give it as many light coats as you can within a 1/2 hour... AFTER A 1/2 (30 MIN) you have to stop! or else the paint will bubble, orange peel, and never give you the strength and quality you want... this is no JOKE
- wait 24 hrs to handle the item
- wait a MIN of 1 week (7 days) for any re coat or sanding and re coat
paint used: rustoleum appliance epoxy
*clear coat is NOT needed nor is a primer...
sanded down
paint on
unwrapped
close up
other legs done in it
pics of the legs 3 years later w/o re coat and 30k miles (you will notice that they are almost a SPOT ON MATCH to wet black powder coat)
sanded down
paint on
unwrapped
close up
then your powder guy sucks at prep work... those pipes where done about 2 years ago... i do them all the time... even now wiht the advances that high temp powder has taken (and this is not high temp) you can get gloss black powder that will acutally cure harder the hotter it gets... PBTP sells a high temp that is said to take from 800-1200 (i have not laid it yet but i have LOVED everything else i shoot from them)
rounder... IT IS 220! thanks for catching that!!! i will change it up now... my bad my bad!
You're the man Joe - thanks for this. One question:
Since this paint is so tuff and seemingly easy to apply can I use it instead of powder for things like my fender strut covers, forward control mounts etc?.....I've been saving up a few items to take to powder coating but if this stuff will do the trick and hold up over time then I'm thinking I'll just rattle can them instead......
i powdered all that on mine, mainly cause i do powder... but i would not recomend the paint on stuff like that as it does not take to wear like powder will... i did a brake pedal in it and after about 3 weeks the contact point where my foot hit is it was down to bare metal again... on f controls and struts i would powder them so when you are using your sissy bar or have bags they dont rub down or where your feet hit they will rub down as well ... but it is your call bud
