Fat Bob 2" spacers for risers
Old Jul 12, 2009 | 08:20 AM
wilcher's Avatar
wilcher
They raise up higher 2 inches and just slightly back toward you since the risers and the new spacers are angled back at you. Way more comfortable. Not so hunched forward now.
Old Sep 27, 2010 | 07:44 PM
Robert Le Gras's Avatar
Robert Le Gras
I really do like these spacers: beautiful, easy to install, allows you a different handlebar range. . . .
I've had them on since Saturday afternoon. About three hundred miles. I'm beginning to think my clutch line is too taut. I'm going to look tomorrow to see if there is any slack I can take up. . . . If not. . . may have to spring for a longer cable.
Old Sep 27, 2010 | 07:47 PM
ridebob10's Avatar
ridebob10
Looking good..that may be on my list of to-do's!
Old Sep 27, 2010 | 08:20 PM
TROD's Avatar
TROD
Would like to get the HD 6" pull back risers, but for the price difference. I may just go this route. thanks for the info
Old Sep 27, 2010 | 08:44 PM
maddghost's Avatar
maddghost
Clutch cable shouldn't be a problem,mi9ne is just perfect.
They work real well,but look kind of goofy without a tank lift IMO! Check my sig pic!
Old Sep 27, 2010 | 09:20 PM
Robert Le Gras
Well, my clutch cable is very tight when I move the front end all the way to the side. Worries me. May be taking the risers off. . . (?) . . .or getting another cable (?) or. .. .?
Anyway, in all other matters this is a great product.
Old Sep 27, 2010 | 10:50 PM
thebutcher307's Avatar
thebutcher307
6th Gear
Robert,
Your factory cables are long enough, just pull a little slack from the neck of the bike. *Sorry I should have spent more time reading. You can't pull more clutch cable from the neck, my bad.*
The factory length is perfect. At least it is on my 08.
Loving the risers! Tank lift this weekend!
Last edited by thebutcher307; Sep 27, 2010 at 11:25 PM. Reason: Need to learn to read.
Old Sep 27, 2010 | 11:08 PM
wilcher's Avatar
wilcher
Robert, no issues with cable length for me. Slightly tight at full turn both directions, but not to the point of causing stress for cables or worries for me. I did lean both clutch and front brake levers down about 5-10 degrees to help though FYI.
Old Sep 28, 2010 | 06:21 AM
Robert Le Gras
I guess I'll try angling the levers down. Thanks. It doesn't SEEM to be a problem, but I just don't want to stress the cables and have a breakdown. I've been taking long rides out into the boonies.
Old May 3, 2012 | 06:37 PM
jpwelch850's Avatar
jpwelch850
Just installed, very easy. However the handlebars seems "spongy" when I pull the handlebars. Never tried before I added the 1 inch spacer. Assume its normal with the rubber bushings in there. I know its tight plus blue loctite.
