Old 02-18-2015, 10:49 AM
How-Tos on this Topic
Last edit by: IB Advertising
Thug Style / Club Style Dyna pic's
http://www.hdforums.com/forum/dyna-g...yna-pic-s.html
ISSUE
Member Lama is in the process of modding his 2007 FXDC into a club style or thug style bike (known today as outlaw bikes) Asks members to provide inspiration and post pictures of their own bikes. Members show off their bikes.
Read below for the full discussion…
Print Wikipost
Old 10-12-2018, 11:49 AM
theduroche's Avatar
theduroche
theduroche is offline
Then an FXR'll be my goal once I can make some cash off the ducati.
But that ain't easy in the Canadian fall.
Any preference of years for the FXR? I know the rear shock angle changed.
  #13372
Old 10-12-2018, 12:04 PM
Jake707's Avatar
Jake707
Jake707 is offline
You should start another thread as there’s tons of info on FXRs from the old heads that had them since new and the younger guys who are still learning and applying new school tech to them.
But at a 30k foot level view id say anything after 90 so you get a splined shaft and most of the bugs worked out.
Shock angle is just the fender struts. Swap those for earlier RP or RTs or get some Arlen Ness ones and customize like I did. Both shock mounting holes positions are drilled into the frame.
  #13373
Old 10-12-2018, 12:16 PM
theduroche's Avatar
theduroche
Thanks a bunch!
  #13374
Old 10-12-2018, 02:17 PM
GREENOHAWK69's Avatar
GREENOHAWK69
GREENOHAWK69 is offline
I wasn't able to find anything specific in the forums, but please feel free to direct me to any threads.
Please and thanks.
[/QUOTE]
Lithium batteries are almost 10 lbs less than regular batteries.
  #13375
Old 10-12-2018, 02:19 PM
theduroche's Avatar
theduroche
Yeah, I thought of going with one of those.
I heard the chargers are expensive though.
  #13376
Old 10-12-2018, 02:24 PM
Jake707's Avatar
Jake707
Jake707 is offline
Please and thanks.
Lithium batteries are almost 10 lbs less than regular batteries.[/QUOTE]
I have one and will say this. They are stupid light. You’d think they were hollow shelf displays. They have plenty of power as well.
HOWEVER what I was NOT told about when being sold on it was that these batteries need to “warm up”. What that means is if it sits longer than an hour or two when you hit the starter it will struggle just like a dead battery. But let the starter button go then hit it again and it’s like a brand new battery. So you basically need to double tap the starter. It’s not a deal breaker but it’s dam annoying when out and everyone looks at you like your battery is dead.
Shaunchez (10-25-2018)
  #13377
Old 10-12-2018, 02:29 PM
theduroche's Avatar
theduroche
That's a great tip.
I'm sure no one would've told me that.
Thanks.
  #13378
Old 10-12-2018, 10:55 PM
pheur's Avatar
pheur
pheur is offline
Huhh.. need to test this, had a brand new (a year ago..) that I concluded as bad (and I could not return it). Need to load it up and see if it might be good after all.
Anyone else that know about this, can confirm? I just last week put my bike in winter storage so I can't test for a few months.
  #13379
Old 10-25-2018, 06:38 PM
Shaunchez's Avatar
Shaunchez
Shaunchez is offline
Yep. Mine does the same thing, gotta hit the thing twice and it starts right up. Had it for about a year and a half, been doing it since day 1.
  #13380
Old 10-26-2018, 08:57 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,028 Likes on 651 Posts
I've been running a Predator Mount for about six years (I think) and scored a true track kit. I've had a brand new front motor mount sitting in my parts horde for awhile and decided to try out the true track.
Front was easy to get on. The rear was kinda a pain. I have the bracket for the 13 inch and taller shocks (I might add). I decided to take the rear wheel off to make it easier and I'm glad I did. One of my rear wheel bearings was toast.
The predator looks a little worse for he wear but we shall see how I like the true track in comparison. The clearances were very tight in relation to my swingarm.
It should also be said that I live in Florida and ride in all kinds of conditions so everything rusts.
Quick Reply: Thug Style / Club Style Dyna pic's
