Widest Rear Tire on Wide Glide?
So what is the widest rear tire anybody has actually put on their Wide Glide without a kit? I have a punctured tire and was going to go with a Metz 880 in a 160 but the 170 is actually cheaper (a few dollars so basically the price diff is a moot point). Will there be any performance pros/cons of going from a 160 to a 170, assuming it can be done?
I know Pirelli and Avons come in a 180+ but based on reviews I have found they don't appear to last as long as Metz. Plus I've had Metz on previous bikes and loved them so I am sticking with them for now.
Not sure on the 07, but the 05 takes a 160 easily, but any wider and you WILL have to make some mods. I have been told by someone I trust you can do a 180, but not on the stock 16" wheel, you need an 18" wheel and you have to make some mods under the fender.
Even with a 160 I had to change the way the bolts are fastened through the struts. The problem is the wheel is not exactly centered in the well.
Nice...what did you have to mod? Fender horns? The 180 will fit with the stock swingarm.
I ask as I have a '97 and am also running a 180 Metzler, but had to modify the fender horns to make them wider. Running a Softail rear fender also.
