Engine won't prime when I press "RUN"!?
Old Jan 28, 2010 | 10:10 AM
chuckieb's Avatar
chuckieb
I appreciate the help, I am going to try to figure this out this weekend. I'll let you guys know what it was.
Old May 25, 2010 | 05:05 AM
gypsiejj's Avatar
gypsiejj
6th Gear
hi chuckleb, i have the same problem how did you sort it ? was it the fuel pump or ecm?
Old May 25, 2010 | 05:50 AM
Sandcrab's Avatar
Sandcrab
Same thing happened to me and it turned out to be the hose from the fuel pump in the tank to the fuel filter in the tank had split and so fuel pressure could not build up but just kept recycling it inside the tank. With most fuel removed from the tank, small flashlight, look inside the tank and turn on the run switch to energize the pump, and see if you see fuel spraying out somewhere.
Old May 25, 2010 | 06:18 AM
badwiser's Avatar
badwiser
If I read the OP right, he said it won't prime in run postion but does in the off postion. this sounds like a dead short in the wiring. or bad switch. I'd start with the switch.
Old May 25, 2010 | 07:21 AM
01harleygal's Avatar
01harleygal
X2
To replace fuel line in the tank (it chafs against the tank inside) you have to buy the fuel pump also as they are one piece. That's what the stealer told me at the time. I don't know if that would be the case now.
Be prepared to spend a few dollars. It was around $300. Canadian a few years ago.
My bike had 20,000 kms on it at the time when it happened, the stealer said it is a common occurrence.
Old May 25, 2010 | 07:24 AM
Nikon D700's Avatar
Nikon D700
I wonder if anyone noticed that the OP was from January.......
I hope it was fixed long ago.
Old May 25, 2010 | 10:04 AM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by chuckieb
2006 Dyan Street Bob. I press the "run" button and listen for the fuel pump to start priming the engine...and it doesn't happen. When I press the "stop" button, it makes the noise like it's priming. Any ideas? The engine just cranks and cranks but will not turn over.
I checked the fuses
Has gas
Battery is good
Any help would be appreciated
Originally Posted by Taddeoeg
Have to agree with Jaron. Since it does everything it is supposed to when you hit the appropriate buttons, the wiring sounds like its good. Engine turns over just won't start - either not getting spark or not getting fuel. Bad fuel pump is a good bet.
Originally Posted by rounder
bad fuel pump, also, is there a fuse for said pump. could have blown somehow. I have a carb, so unsure if it has it's own fuse. I doubt it is spark if your fuel pump is not priming.
This doesn't make sense because if the pump was bad it wouldn't work at all but you say it works in the off position or at least sounds like it's working. You haven't done anything with the wiring. I guess I'd start at the switch and work back.
Old May 25, 2010 | 10:53 AM
Grendel4's Avatar
Grendel4
My salesman suggested I not use the 'run/'off' button on the handlebar. Not sure why except that he opined that they have a tendency to go bad if you use them a lot. I put it down to over-cautious salesman. But he's been selling Harleys for over ten years, so I dunno.
Maybe if he did bars, grips or chrome switch covers or something that would require him to disassemble the handlebar switch cover, maybe a wire got pinched or pulled loose, or lost its connection. Even if it's been a while since he did it, maybe the wiring just now shorted out.
Whatever.
I'm with you, check the easiest and cheapest possibilities first. Too many times, peeps leap to a conclusion, fix something expensive and later find out it was a five dollar part.
Old May 25, 2010 | 11:49 AM
HDTech74's Avatar
HDTech74
Sounds like a bad fuel pump fuse or bad pump.
When the line in the tank has a hole in it, the pump will still prime
but you can hear the fuel squirting on the inside of the tank.
Never heard of the switch going bad.
He says he hasn't touched the bike yet.
Any codes?
Did you use the self diag on the bike?
Old May 25, 2010 | 12:20 PM
red devil's Avatar
red devil
How about the fuel pump relay?
