True Track opinions
Vibration is not noticeably different for the TT itself but you do loosen up motor mounts and if you change alignment then the vibrations could be better or worse. There is a lot of vibration variation from one bike to another without throwing the TT into the equation.
I haven't heard of any problems here, except that some accessories are more difficult to fit without modifications and that the rear install can be a PITA and a tight fit. Sputhe makes a smaller stabilizer that is easier to fit with accessories, and if you want to save some $$ or spread your expense out, they will sell you both halves separately.
But as you have read, some riders don't notice much difference, others wonder how they lived all those years without one. What camp you fit in depends on how much you notice the tracking and how tight your bike is to begin with. Many here will argue that better suspension and tires will make much more of a handling improvement.
The front stabilizer is so easy to put on that its worth a try. Its about a 15 minute job and certainly doesn't hurt. Anything for the HD bike is overpriced IMHO.
Personally I'm used to riding sport bikes and I noticed the handling improvement right off. But I wouldn't call it a significant change.... just feels much better at speed.
Now, if I take the same bike and try to run big radius turns, where the speed is above, say 60mph; a whole new can of worms is released as the rear wheel tracking gets downright scary. No doubt an engine-frame-swingarm stabilizer is going to be a big help..... but I just don't have the cajones to lean the big beast over at really high speeds, with the marginal, non-sportbike suspension and brakes, combined with the frame flex that will occur with the huge forces generated by the higher speeds. Bottom line, my (raised) Dyna handles fine at speeds less than about 55-60 mph and full lean angle, on mostly smooth twisty roads w/o engine mount stabilizers. It handles fine in normal riding and freeway x-country cruising as well.
Also, the twisty road pics were taken w/o the front fork Superbrace that I have since put on the machine. Not sure how much of a difference the Superbrace causes, cause I don't think I can really feel the difference in normal street riding.
Centerline, all I can tell you man, is, those first two pics, I feel like throwing em on my desktop as wall paper, that is to cool for school. And that last pic, of that burned up peg, well man, that friggin gives me wood bro.
Very nice, looks like you got some good gear on too for those, twisty's, and that I respect the hell out of....
