Rubber Engine Mount & Oil
How big a deal is getting some oil on the front engine mount? I try to catch as much as possible during an oil change, but inevitably some makes it's way down to the mount and frame. The FXD shop service manual doesn't say a thing about it in the oil change section.
You need to get it off of there. The front mounts are questionable anyway, and oil deteriorates the rubber pretty quickly. I usually take a spray can of citrus based cleaner, give it a good shot down it's chin and rinse thoroughly.
'course I also use rags, and a 32oz pop bottle cut in half at an angle to catch the oil.... along with dropping the voltage regulator so I can get to the area unrestricted.
By 'preload' do you mean the rubber mount is under excessive compression and thereby unnecessarily transmits more engine vibration to the frame? The bike vibrates pretty good when it's idling, but it smooths out early at speed.
I am hijacking this thread to over here:
https://www.hdforums.com/forum/dyna-...ml#post6451892
Asking about replacing the engine mounts.
I just ordered the Front MotorMount Stabilizer, bottom right in this picture, from my local Indy, after telling him I had to replace my front motor mount he said he'd used these on a number of bikes and it made an improvement in the shake at idle and over all smoothness and it took wieght off the mount which should improve the life of the mount. It's in the Custom Chrome cataloge.
