Battery removal on a 97 Wide Glide
If your 97 is the same as my 95 this is how you remove the battery. First remove the seat. Disconnect the battery cables. Standing on the right side of the bike there should be two bolts on the left side of the battery tray that mount it to the frame. Remove those two bolts. Then on the back side of the battery (between the posts) there will be another bolt. Loosen that bolt, and it should lower the battery tray. Loosen it just enough to remove the chrome covers, then remove the battery from the tray.
Hope that helps.
Hope that helps.
