Evo compression ratios 9.5:1 or 10.5:1
I'm just days away from building an 80" Evo.... I have the parts to build a stock engine, a 9.5:1 engine or a 10.5:1 engine. I have stock heads and "Head-Quarters" ported+milled heads. What I would like to know is what are some pro/cons of a high compression EVO?????
Hard starting?
Idle rough?
can I run 93 gas?
will it run hot?
Thanks for any info!!
P.S. it's a 93 fxdwg
Hard starting?
Idle rough?
can I run 93 gas?
will it run hot?
Hard starting?
Idle rough?
can I run 93 gas?
will it run hot?
Hard starting?
Idle rough?
can I run 93 gas?
will it run hot?
I have also since did the Diamond Cutting to my Cylinders and Heads. Also have changed to a, for now, S&S A/C and a Big PSI Carb. Have not gone to the tuner yet.
Hope this helps.
Glad you mentioned the starter...after I had work done on the bike, they did recommend going to a bigger starter as mine was having problems.
It is a bear to start without the releases. It bucks something fierce if they aren't engaged.
The benefit to having higher compression is that it gives you more consistent torque through the gear. Stock EVOs stop pulling at 3500 RPM - the higher compression will get you to 6000 easily.
As an after-effect, the exhaust "pops" better - not backfire . . . more like a top fuel racer.
I guess it depends on the gas in your area. I talked to a guy the other day that has a 10.5:1 Evo. He said his pings pretty bad on 93 octane, and he puts octane booster in it if he's going to run it hard. But, all the stations around here have that 10% Ethanol crap.
My Evo's 9.5:1, and I've had no issues. Maybe you could go in the middle and get some 10:1 pistons? I would probably get compression releases if you go anything over 9.5:1.
