Active Exhaust Control - how to deactive
#42
You really should just change the whole exhaust pipe.
But if not, then physically open the valve and then fix it open with a screw, wire, rivet etc. Then disconnect the cable that goes to the solenoid motor - or just pull the motor out and throw it away. Then just tuck the connector away.
I'd still say replace the whole pipe though...otherwise you still have the catalytic converter in there.
#43
https://www.hdforums.com/forum/dyna-...a-2010-wg.html
I'm waiting for the delivery of it, should be this week
Now, I'm thinking to completely remove this damned AEC. (motor, wire and butterfly valve).
Do you know if the bike will give errors for the missing AEC valve motor?
#44
#45
Hi adm, I'm gonna replace the whole exhaust of my 2010 Dyna as posted in the thread
#46
#47
have deactivated active exhaust with tuner
I deactivated the ective exhaust with my power vision tuner, same can be done with a SERT.
However once done the valve is left in the default closed position on my 2014 fatbob.
so upon closer inspection I can see that the cable drive mounted on the battery box has a convenient sized 29mm nut that if you turn counter clockwise it pulls the cable and opens the valve. the resistance provided by the motor is enough to overcome the spring tension on the valve and thus leaves the valve open.
problem solved, bike is now running through both pipes at all rpm and speeds.
see the attcahed pics to show the cable "nut" you need to turn.
#48
Sorry for bringing this back up but I have a question 'bout the active exhaust valve.
I'm planning on having my pipes, short shots, replaced by stock pipes for my Street bob 2007.
These pipes have the active exhaust system, and because the module is not installed, I would like to take advantage of the fact that now I can leave it of.
But blocking the valve in open position and keeping it there, is somewhat a problem.
How do you guys go about this and could you share maybe a picture.
Tried to read it, but english is a bit difficult sometimes.
Greets from Belgium
Ride safe.
Greets from Belgium
Ride safe.
#49
Do
You can check by leaving the bike on the stand, in Neutral and giving it a bit of a rev while watching the butterfly solenoid on the pipe.
When you start, the butterfly opens (as the exhaust is not so loud at idle), when you rev it you'll see the the solenoid activate which closes the valve at higher revs to dampen the sound.
#50
