MoCo Bullet Headlamp Install
I want to install it myself and the pdf instruction sheet from the Harley website says you gotta take the gas tank off. So I go and check my trusty Service Manual and it looks like a PITA. Maybe not to those of you that have done it several times, but I'll be re-inventing the freaking wheel. As usual.
So while I'm in the SM I decide to check on 'headlight removal' and the SM says you can slide the gas tank back to get at the wires.
Hmmmm, sez I. Conflicting instructions. From Hardly Dangerous? Imagine that.
The biggest reason I want to know is that if I gotta remove the gas tank (which entails taking off the instrument panel, IIRC) then I'm gonna get my combo tach/speedo at the same time. If I don't, I'll wait. Money doesn't grow on trees in the Grendel household and the War Department don't wanna hear about getting a 2nd job to fund my Harley habit.
Also, if I gotta take the gas tank off, I gotta make a plan or two. Like maybe do it at my neighbor's house cause gas is gonna drip all over the floor of my garage. No big deal to me, but the afore-mentioned War Department will not be happy. Gas fumes give her migraines. I've never had a migraine but I understand they're no fun. So I try to be thoughtful of what gives her those nasties. Fumes of all kinds. Except fingernail polish remover doesn't seem to bother her. I make her go outside when she uses it cause I hate it. Go figure.
Oh yeah, I did several searches and read several threads that weren't really all that helpful.
Thoughts and tips would be appreciated.
No takers, huh?
C'mon guys, I just wanna know if anyone has had success sliding back the gas tank on a late model dyna to get to the wires for the headlight or if removing the gas tank is the best/only way.
One of my concerns is the crossover tube. Another is getting to the cover under the main frame and whether that's even necessary.
I'd appreciate any input.
I'm no professional but it should be an easy job as long as you take your time.
2006-Later FXD:
5. Disconnect 4-place headlamp connector [38] from main
Maybe its because I always tried to use an electric soldering iron. Dunno. Never could get anything to stick right. Never.
A man's got to know his limitations. And soldering is near the top of my list.
Hard to jam them all in but read this morning that if you pull the wires from the seat section rather then jam back in they go a lot easier.
I would recommend looking at the Cobra ll light from Eastern Performance. It looks very similar and is only $99 shipped. I have had mine for over a year and still looks brand new. You would have to cut and splice it though.
