Help - Security won't disarm unless I enter PIN
Old 08-18-2010, 06:13 AM
June Bug's Avatar
June Bug
June Bug is offline
Default Help - Security won't disarm unless I enter PIN
I have an '08 Street Bob. Something has gone wrong with the fob and/or security system. I couldn't start the bike and finally figured out it was remaining armed, so unless I go through the whole process of manually entering my PIN, it won't disarm and I can't start the bike! I even brought out the extra FOB, thinking it was something to do with the FOB I've been using since I bought the bike.
This is very quickly becoming a pain in the butt to put it mildly.
Is this common? Is there a quick fix? Can I (well, my husband ) take the whole damn thing out? We have the service manual for my bike but he can't find anything on how to do that. I don't want to have to pay the dealer to do what we maybe could do ourselves.
Thanks!
EDIT / UPDATE / ....
Um .. yeah ... t'would seem it was the battery. In BOTH Fobs. (makes sense seeing they are the same age).
Thanks for the replies.
Old 08-18-2010, 06:48 AM
Kelly_A's Avatar
Kelly_A
Kelly_A is offline
It's possible both fobs have bad batteries. Replace one before you try anything else.
Old 08-18-2010, 08:15 AM
Taddeoeg's Avatar
Taddeoeg
Taddeoeg is offline
Yes, you can remove the security system, but you have to replace the module. Check your service manual for "TSM" and/or "TSSM". The former is the stock unit while the latter included the security feature. Removing it is easy.
For those who want to go the other way, things get more difficult. You can easily replace the TSM with a TSSM yourself, and teach the ECM to recognize it, but you must take the bike to the dealer to "marry" the fobs to the TSSM. If you were to sell you old unit (assuming it isn't defective) I'm not sure whether the buyer would have to have the dealer marry the fobs since they already are. Just don't know if the act of moving the unit to a different bike would interfere with that.
That all said, +1 on checking the batteries. It's usually the simple, obvious stuff we overlook that causes most problems.
Old 08-18-2010, 08:17 AM
inaroush's Avatar
inaroush
inaroush is offline
Put in fresh batteries it is probably a simple fix... Dont make yourself crazy just yet
Old 08-18-2010, 08:19 AM
rscalzo's Avatar
rscalzo
rscalzo is offline
New batteries but clean the terminals of the FOB's buy rubbing a hard eraser lightly over them several times. There might be some light corrosion. I'd even go the additional step of coating the terminals with dielectric grease.
Old 08-18-2010, 10:20 AM
Romeo's Avatar
Romeo
Romeo is offline
Could you have done something to inadvertently disconnect the antenna from the security module or the antenna itself? Pull out the security module to see if the smaller of the 2 connectors (the one on the left) is connected. You may have to follow the cable from that connector to the antenna module (mounted behind the electrical caddy, under the seat) to see if the other end is connected as well.
Old 08-19-2010, 01:24 AM
midnitewolf's Avatar
midnitewolf
midnitewolf is offline
Same thing happened to me , the batteries were dead in both
of them
New batteries problem fixed
Old 08-19-2010, 11:15 AM
mahagowitz's Avatar
mahagowitz
mahagowitz is offline
buy a 2 pack of batteries and change a fob, keep other battery for next year
Old 08-19-2010, 11:30 AM
ratt196635's Avatar
ratt196635
ratt196635 is offline
had the same problem and mine was also the batteries.
Old 08-19-2010, 11:55 AM
CRF's Avatar
CRF
CRF is offline
how long are the batteries supposed to last in these things? I've had mine for 2 1/2 years now and they are still working (knock on wood) but I've been thinking that it must be getting to be about time to swap em out.........
Quick Reply: Help - Security won't disarm unless I enter PIN
