Best oil filter wrench for Dyna
Old 09-29-2010, 12:55 PM
nkauf21's Avatar
nkauf21
nkauf21 is offline
Old 09-29-2010, 01:02 PM
GREENOHAWK69's Avatar
GREENOHAWK69
GREENOHAWK69 is offline
Originally Posted by Shizims
I use a $2.95 metal cap style one that I got at Autozone. I can't remember the size, but I took the new filter in the store and checked the fit. Works great (you'll need a 3/8 ratchet and an extension bar helps).
I use this or my channel lock - either one works fine.
Old 09-29-2010, 01:53 PM
cornishman's Avatar
cornishman
cornishman is offline
I use similar, it was for my previous bmw. Dead easy to use and no mess, remember to use a glossy magazine cover or similar to roll into a half circle and place under the filter to channel the oil away from your frame into a receptical when you undo the filter.
Old 09-29-2010, 02:48 PM
fxdx-fly-by's Avatar
fxdx-fly-by
fxdx-fly-by is offline
i have one that looks like a C and it adjusts to diff sizes... works like a charm holds a extention off a rachet
Old 09-29-2010, 03:43 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Filter Wrench
I use a strap wrench that was made specifically for oil filters. I have the end cap style also, but the fabric strap never met a filter it couldn't remove and without slipping.
Old 09-29-2010, 03:59 PM
GPHDXLC's Avatar
GPHDXLC
GPHDXLC is offline
Originally Posted by Wyde Glyde Bry
I agree with craig -- I use HD's Oil Filter Wrench End Cap Style (94863-10) and it is slick. Not often you can find a cheap part at your HD dealership... and it actually works perfectly to boot. Never a problem.
That's the one I have and it works great.
Old 09-29-2010, 05:25 PM
stewbeezer's Avatar
stewbeezer
stewbeezer is offline
I use K & N's Filter, like the nut on the end.
Old 09-29-2010, 05:50 PM
Squirrel67's Avatar
Squirrel67
Squirrel67 is offline
I got a strap wrench from tractor supply fits a 1/2 inch drive rachet with extension. Cost about 4 bucks and will remove any filter.
Old 09-29-2010, 06:40 PM
maddghost's Avatar
maddghost
maddghost is offline
Gettin the filter off is easy it's keeping the oil off your engine block and motor mount is the trick!
Old 09-29-2010, 08:20 PM
dyna rider's Avatar
dyna rider
Default Oil From Filter
With the bike on the jiffy stand, I use a punch to flat spot the filter end at the top and bottom, then I drill a hole at the top and bottom. I put a cheap flexible cutting board under the filter to drain it into an oil catch pan. If you warmed the oil before you started and let it drain for about an hour, before removal, there isn't much let for the front motor mount.
Quick Reply: Best oil filter wrench for Dyna
