widest tire for a 2001 Dyna?
I have a 2001 FXDP with the run-flats that are just about done. I searched here for anything that might relate to the widest or meatiest tire I can put on this bike. I believe the stock size is a 130/90 or so, but it's on the tire as MT or MU...cannot recall just now. Has anyone done anything wider like a 140/90 or 150/80? I see that these sizes are available. Can you let me know what will work? Thanks!
My '04 WG runs a 150 rear. I don't think there's anything different in the swingarm between your bike and mine, so I think you should be able to get a 150 in there w/o a problem.
I have an 02 dyna, in 2002 they stasrted using 150 tires, prior to that they use the 130, the difference is in the fender width, i bought a fender from an 01 and it was actually a 1/2 narower. so be carefull and measure for clearance
I have an 03 Wide Glide with a 150 on it is it possible to put a 160 on
tire
Originally Posted by Robtarra39
(Post 7439260)
140/90
Originally Posted by Bigfoots03HD
(Post 7439413)
On your 2001, without any modification you can likely only go with a 140. Since I converted from a belt to a chain I can just squeeze a 150 in but it's tight. I'm riding on the Avon Venoms (widths vary from one manufacturer to another) and the rear fills up the fender and looks good.
If you want to go bigger 180 or 200+ that would require some serious mods. |
Wil9er
Originally Posted by chucksterd
(Post 7436507)
i have a 2001 fxdp with the run-flats that are just about done. I searched here for anything that might relate to the widest or meatiest tire i can put on this bike. I believe the stock size is a 130/90 or so, but it's on the tire as mt or mu...cannot recall just now. Has anyone done anything wider like a 140/90 or 150/80? I see that these sizes are available. Can you let me know what will work? Thanks!
ok i think im pretty sure 130 came on a sporty that yr. Also you need to change the pulley to a o2 to 06 . Also you need the 1 1/8 belt your bike may have the 1 1/2 you can go with the 150 i think you already have a 150 140 tires came on the 99 dyna. Anyway just go with the 180 or 160 it will work i just did it i used a 1in pulley from a 07 dyna and a 180 wheel from a 03 duece good luck you need a 1in belt for this set up. Ps look for a fender too dm cycles makes one. cant be 100% but i think the 01 came with a 150 if not yuo have to get the pulley and belt, so i your doing it anyway go to 180. |
(Post 7439413)
yes i did it once on my 03 superglide i had use the stock rim i took it off it looked to balloney. like a monster truck does i think it would look better with a wider rim |
© 2024 MH Sub I, LLC dba Internet Brands
