Mod. back plate on Ness BS
I'm getting a little bit of oil dripping out of my A/C on to my engine, the Ness back plate is not doing a very good job of venting the oil back into the engine which I understand is
common problem. The oil level is about half way up the dip stick so it's not over filled, so instead of buying a new breather system I thought first I'd try to modify the back plate maybe with some hose or something, has anyone tried this? It's always dripped a little seems it's getting worse, I'm open to suggestions, thanks, Paulie |
I run an Ness Big Sucker AC and have no drip problems. Doesn't mean you dont need to remove it and clean it occasionaly though. Just a thought.
Yes I pulled the thing apart and cleaned everything
Originally Posted by paulies 07
(Post 7677217)
what colour is the oil?
Just reg. oil color, not dark or anything, I use Amsoil 20-50
© 2024 MH Sub I, LLC dba Internet Brands
