old school tires anyone?
hi folks,
I really like the looks of those Avon Speedmaster or Cocker, but my indy doesn't recommend them, says they are way to slippery in the rain and unstable at motorway speed (European speed that is...)
so if some of you guys are running old school tires on a daily basis on your Dyna I would appreciated your feed back with this set-up
thanks
thanks
I ran the Cheng Shen copy of the Avon Speedmaster which is of course a copy of whatever the 21 that was popular in the 60's. My Chinese copy was probably 1/3 the quality of the Avon and I never had the slightest issue with it at all. It was a cool looking tire, thats for sure and when I burn up the Avon Venom thats on the Springer now, I have been planning on the Avon Speedmaster as my next tire. I totally understand your concern about a vintage tread design, but I can only suspect that a premier tire manufacture such as Avon would never build a tire that is unsafe on European or American roads.
edit. Just wanted to mention its intended I believe for a 2.15 skinny rim.
Most feedback I have gotten from them was less than stellar performance. I would still use them though, as long as you dont expect high performance from them they will do.
I prefer the best tire I can get on my current ride, but if I had a rigid springer I would have a Speedmaster with a Coker rear for sure.
I have two feelings about this subject. One is that modern tyres, even if they look like old ones, should be made using modern rubber compounds, so it is reasonable to expect them to ride a little better than they did a few decades ago.
On the other hand, there is a good reason modern tyres look different! They are made using much more hi-tech designs of construction, as well as tread pattern and rubber compounds. IMHO modern performance overcomes any wish for old fashioned appearance!
Thanks for your input guys, I think GRBROWN made a point there, can’t do anything but agree, BiKERLAW, when I see those japs riding their FLH like sport bikes I wonder if those tires are so bad as my indy say they are !
I don’t like riding in the rain, but last May I did 1600 miles in pouring rain to go to a meeting on the French Riviera…
I’m riding 90% of the time alone or following my wife on her XB9 Buell, and that’s cruising… so no problem with not so hi-perf tires, the problem is the 10% left, that’s when I ride with the gang, and that’s really no cruising !
I cant buy 2 sets of tires !
