Lifted Gas Tank up to do some work...FUEL LEAK
I was lifting my gas tank up to run some wires under it, I lifted it up and saw gas leaking everywhere...got the line that was leaking, the left side of my gas tank where a fuel **** would be, sept mines EFI 2006 Dyna Wide Glide. After the gas was drained out I see where the fuel line would go, but the problem is there is this lil plastic piece that has a blue button on it, you push the blue button and it'll slide off the what I'm guessing is the EFI fuel unit. After you do that you can see it looks like it mates up with the fuel line, but there is no way to really secure it, seems to me its going to leak. Has anyone removed a gas tank off of a 2006 Dyna and know what I'm talking about. Or can show me where I can see a diagram or w/e?
RE: Lifted Gas Tank up to do some work...FUEL LEAK
ORIGINAL: rap87
When that line is disconnected there should only be small amount of leakage (a few drops).
Unless you broke something. I think JohnBear mentioned this a few months ago.
When the line is unhooked, there is a chrome ring/sleeve that stays with the tank.
It slides up to release, and back down to secure.
It is a real simple connector. Not sure about the blue button thing.
mud
i did the same thing putting led lights on my streetbob . go to dealer tell them you need the fuel line that goes from tank to motor it has a button on the fuel line fitting one attached to motor push button in pull off motor then push up on chrome piece at tank and pull fuel line off take to dealer get new one snap back on its real easy can send pics of how to if you need
[IMG]http://users.adelphia.net/~michaelltodd/small06bob.jpg[IMG]
