Can I raise my handlebars???
Old Mar 9, 2011 | 05:21 PM
CobraEd's Avatar
CobraEd
Default Can I raise my handlebars???
I have an 07 Dyna Super Glide. I am thinking of adding risers that are 1" higher and 2" back. Do you all think I can do this without replacing any control cables or lines?
Old Mar 9, 2011 | 05:29 PM
heinigerich@yahoo.com's Avatar
To be totaly honest, I think that the riser fad is pretty rediculious. I realy thing it looks gay. If you want to raise your bars, get lomger bars noth toothpicks that hold up bars. BUT, To Each His Own. That is my opinion.
Old Mar 9, 2011 | 05:45 PM
bobnehoc's Avatar
bobnehoc
I have not done that mod to my bike but after seeing numerous posts about bars, risers, cables and wires I believe that there is enough slack to do the mod without replacing the cables and lengthening the wires. I am sure someone with more knowledge on this will chime in soon....
Old Mar 9, 2011 | 07:50 PM
CobraEd's Avatar
CobraEd
A new bar is not expensive, and would probably look better, but then I will not be sure on the effect it will have on the linkages. Looks like a lot more work too.
Old Mar 9, 2011 | 07:58 PM
SuperFastGlide's Avatar
SuperFastGlide
theres plenty of slack for the risers your wanting. although, on a superglide if you use a pull back type riser youll change the angle of your speedo, to a more straight up position...
Old Mar 9, 2011 | 08:09 PM
tscreener's Avatar
tscreener
Default been there done that
I did that and i am now going with bars they should be here friday. I dont like the speedo placement with the longer pullback risers, and it looks odd.
Bmatt
Mar 22, 2014 08:14 AM
ghoticov
Mar 8, 2013 04:45 AM
bubba626
Apr 12, 2010 03:09 PM
handgunner
Jun 10, 2009 07:56 PM
trat73
Jan 10, 2009 12:04 PM
