Tech said to remove O2 sensors with fuel pak
I spoke to a Vance and Hines tech earlier as I had a question about closed loop operation. He said that the fuel pak will only work and modify fuel in open loop. In closed loop, it does nothing whatsoever.
He went on to ask me whether I lived in California. When I said no, he replied that I should pull the 02 sensors and that the fuel pak would then control the closed loop tables. I asked if that was a good idea, in his opinion, and he replied yes and that the bike would run much better with the map in the fuel pak.
Has anyone else heard this? or tried this?
Never heard that one, maybe someone else here has. I didn't think that the Fuel Pak controls your AFRs, so how would the ECM know how to respond to varying conditions? I had one of those on my bike a couple of years ago and had plenty of discussions with the V&H techs. Nobody ever suggested to disconnect the O2 sensors.
I was a little surprised when he said it as well...I made sure to ask again and he said the bike would run better without them using the fuel pak, and that the values they entered would then cover the closed loop portion.
Sounded fishy to me, and I've never heard a single person mention this either.
