Oil light on.. ideas?
Hello all... I was replacing my mid controls on my 2011 super glide with HD forward controls over the weekend. When taking my primary case off... lots of trans fluid leaked from the bike. After getting everything installed and put back together, I turned the key of the bike and noticed that my red oil light was on. I have 300 miles on the bike... checked the oil level...perfect. Checked the trans fluid and was a little low. I ran to the dealership and got some trans fluid and put about 24 oz in. I started the bike hoping that the trans fluid would cycle through... oil light is still on and I can't seem to figure out why. Does the oil light also turn on for trans fluid? What could possibly be causing this?
Help please
Help please
If I had to guess...and I do, I'd suggest that you may have damaged the yellow and green wire that goes to the oil pressure switch. The switch is located on the front of the motor next to the oil filter housing but the wire runs under the motor and along the chassis in a wiring harness. Check to make sure you haven't damaged or pinched that harness when you jacked the bike up? Just a thought.
Received 4,309 Likes
To the best of my knoeledge there are three cavities for oil on the HD. 1) primary, 2) transmission, 3) engine oil. When you removed the primary cover, trans oil leaked out? I'm with Mud on this, sounds like you may have pinched the oil pressure sending wire or quite possibly diconnected it at the sender unit or a plug.
If the wire is disconnected the light will not come on. It is only on when it grounds. Other than the obvious lack of oil pressure if you eliminate that I would say that the either the wire is grounded out or the sending unit is bad. Disconnect it from the sending unit. If the light goes out the the sending unit is the problem. If it stays on go find the short.
Well the primary and trans oil for this bike is the same oil. I believe its the HD Formula + Chaincase and transmission.
Thanks for the pointers, haven't had a chance to look at the bike wiring yet. Can a low primary oil cause the oil light to turn on? I added to the tranny filler but not the Primary which is the next step I'll take before checking wiring.
Just mssin with ya.
However older Harleys did share the same fluids for both Tranny and Primary chain lubrication.
Perhaps the OP has an older Harley than we do..
