Fuelmoto Dynojet Power Vision
A few months ago I installed Vance & Hines Big Radius 2 into 2 with standard baffles and a "Spike" air cleaner.
After a few months of research, and almost pulling the trigger on 2 totally different products, I decided to purchase the Dynojet Power Vision. It just seemed the most logical choice for someone like me (not a mechanic & not a computer wizard):
1) it comes with a 'tune' for your set-up from Fuelmoto
2) NOTHING has to be cut, glued, zip-tied, or altered on your bike.(this is very helpful cause the under-the-saddle space on our dynas is miniscule)
3) NOTHING stays on the bike (unless you want the Vision on the bike-in which case you buy the mount and put it on the bars)
4) Any and All changes/upgrades you make to the bike later can easily be flashed to your ECM.
5)If you have the knowledge(or are just feeling lucky) you can experiment with different aspects of your stock tune or theirs and make your bike do cartwheels...
Install tips:
1) plug the Vision into the grey plug under your seat.
2) The instructions tell you to turn "On" your bike, this includes the "Run" switch on the handlebars (not mentioned in the instructions). Otherwise the Vision does not "Detect" your ECM.
3) From here on out, just follow the instructions that come with the Vision or check out their video online.
If I can do it, ALL of you can!!
Results: The bike runs GREAT!!!!!!!!
1)NO more spittin' and poppin' on decel (this was really getting annoying)
2)REALLY smooth throttle response throughout the gears-especially notice-able at slower/parking-lot/heavy-traffic speeds.
3) Lower engine temps. My right leg is not burning at the stop lights. This will be tested more thoroughly in July/August when our temps are in the 40's C/100's F.
4) MORE POWER!! I did not dyno the bike, but there just seems to be WAY more 'get-up-n-go' in each gear!!
Conclusion: My bike runs the way it should...smooth and 'cooler' in traffic and
tons of power when I need it. My bike is my daily transport (the car is for rain/snow/family).
Almost ALL of my research and everything I learned about the PowerVision and FuelMoto came from this forum. Thanks to everyone for all your great posts and advice.
http://www.fuelmotousa.com/powervision.htm
http://www.dynojet.com/powervision/p...details.aspx#1
Install tips:
Nope! Once you hook up the PowerVision to your ECM, it marries itself to your bike. It cannot be used on other bikes.
