$$ to cam my fatbob ?
Listen, you can save yourself a lot of install labor by doing it yourself. It's not difficult at all. I'm no mechanic but I was able to do it using my service manual for reference and torque specs/seq.
If you can operate basic tools plus a torque wrench and read/comprehend a service manual, then you can do a cam swap. If I remember I outlined what specific parts you need (gaskets, etc) in a thread called "Cams".
My swap cost me about $750 including dyno tune. ~$500 parts including cams + $250 dyno-tune.
If you're interested:
As far as the gearing, a lot of people have done a tranny sprocket mod, from 34t to 31t. Andrews makes the sprocket. There is a large thread on it. Just search "31t" or something like that.
I didn't do anything else other than cam and exhaust. I should do the heads for maximum compliment to the cam. ~10:1 would be great. Haven't had the money to do it, so that part of the mod will wait.
That cam is ok. Again, several cam grinds that are popular in the late model dynas. Andrews 37, Andrews 54, Wood 6, Wood 408-44, and I'd also give the Wood 5 a look-see. Same as the 6, with higher lift.
I was going to add a +4 advance gear in lieu of doing the heads but that didn't work out either.
The first 10-15hp comes easy/cheap. Once you hit that, it becomes harder and more $$ to gain anything noticeable.
