Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Dyna Glide Models (https://www.hdforums.com/forum/dyna-glide-models-9/)
-   -   FXD Shocks won't adjust (https://www.hdforums.com/forum/dyna-glide-models/663760-fxd-shocks-wont-adjust.html)
TxD11 Jul 8, 2011 09:40 AM
This is a 2005 Dyna FXD.
I have the proper spaner but the shock adjustment ring will not turn.
Any ideas?
perki48 Jul 8, 2011 11:15 AM
If you havn't already tried it jack up the bike so rear tire is off the ground.
ktrick01 Jul 8, 2011 06:54 PM
I know this stupid but I had the same problem even with the correct spanner. The shocks were already at their max up or down. I cant remember. Try reversing your direction.
RAWHIDE07 Jul 8, 2011 08:48 PM
Spray some teflon based lube(Tri Flow for instance) on the bottom adjustment ring,let soak a couple of minutes.Turn both adjuster rings to the lowest position,spray again,adjust each shock to the next higher position until you reach the desired level of preload.
© 2026 MH Sub I, LLC dba Internet Brands
