Do you use anti-seize on spark plugs?
Steel and Aluminum DO NOT LIKE EACH OTHER, when it comes to spark plugs use the anti-seize just like the manual tells you to do. Anti-seize will not cause corroding, thats the whole point. If the aluminum head and the steel spark plug corrode and lock together, you will pull the threads right out of the head. If your under warranty i doubt they are going to fix it if you did not use the anti-seize on the plugs.
tar_snake (10-09-2018)
I've had to have an aluminum head helicoiled before because the threads came out with the plug. Not a Harley, but the same effect, and this was a water-cooled engine.
Just two little dabs, 180 degrees apart, at the start of the threads. It will work its way into the threads as you screw it in. Don't goop it on there like roughnecks do with drill pipe on oil rigs. If you use too much you'll just have a mess to clean up in a hard to reach spot, plus you'll run the risk of it seeping down onto the electrode.
Received 70,147 Likes
