Wideglide console on FatBob
Old Jul 18, 2011 | 03:50 PM
bmcgc's Avatar
bmcgc
Default Wideglide console on FatBob
Since the 08 Wideglide and FatBob use the same tank Im wondering if the wideglide console will bolt up to the FatBob tank and if the wiring harness is the same for both.
The only difference that I can see is the 4in speedo vs the 5in speedo.
The slim wideglide console is much nicer looking than the cheesey FatBob console. I added the plastic chrome lower, but the Wideglide console still looks better.
Old Jul 18, 2011 | 07:01 PM
Bandit29's Avatar
Bandit29
What are you going to do with the Fat Bob console?
Old Jul 18, 2011 | 07:20 PM
bmcgc's Avatar
bmcgc
Comparing p/n's it looks like they dont swap without a bunch of cutting and splicing.
I thought that the tanks were the same because I was looking at a 2008 CVO Wideglide with the narrow console but it turns out that the tanks are different.
Old Jul 18, 2011 | 07:25 PM
Dynaglide68's Avatar
Dynaglide68
Wide Glide and Fat Bob use different tanks
Old Jul 18, 2011 | 07:30 PM
p51bombay's Avatar
p51bombay
I'm ditching my SG/FB console, speedo and all for a CVO dash - finally got all the parts now but still have to send out the lower panel so the chrome matches.........bottom is a sort of smoked chrome. Checked the book and I think everything will swap right over.
Old Jul 19, 2011 | 03:46 AM
Vins's Avatar
Vins
There are several threads on here with dash conversions. They will swap with a little ingenuity. If you can't find them, PM me and I'll post the sights. Have them bookmarked but don't have the time right now to look them up.
Old Jul 19, 2011 | 07:58 AM
8541hog's Avatar
8541hog
08 and earlier WG and all FB tanks and consoles are identical. The new WG tank is smaller.
Old Jul 19, 2011 | 11:57 AM
bmcgc's Avatar
bmcgc
Is the 2008 FXDSE2 tank the same as the 2008 FatBob, they are both 5 gal.
I like this look and would like to swap it over to teh FatBoib if possible.
http://www.totalmotorcycle.com/photo...;EagleDyna.htm
Old Jul 19, 2011 | 12:55 PM
p51bombay's Avatar
p51bombay
I don't know about that one but I've bought the book for a 2010 FXDFSE, compared everything and it looks like a straight swap - you do have to change the top cover as the bracket is pretty different, not something you can just bend to fit.
Old Jul 19, 2011 | 01:25 PM
8541hog's Avatar
8541hog
All dyna tanks will interchange it is the console and instrument configuration that is different. If the console matches it is a straight swap if not you have to decide which console to use and if you need to make any mods.
