70900100 Speedo/Tach
Just found this in the latest HD parts catalog, 4" Gauge.
Anybody know if HD made a gauge size change between the '10/'11 FXDWG and the '12 FXDWG? It doesn't make sense that this new gauge would fit the '12 but not the '11...
***EDIT***
Thread has turned into a call to send an email to HD "Suggesting a new part" to: H-DIdeaSubmissionsSuggestion@harley-davidson.com for pre 2012 dyna's. I put the mail address here to make it easier to find.
***EDIT***
Last edited by ll Legion ll; 08-30-2011 at 05:46 AM. Reason: Thread changed direction
I'm interested in the answer to this as well. I have a 10wg, also with the 4" speedo. This product claims to only fit the 12wg. I asked my dealer if there were any differences in the 12, and was told the only difference is the motor and the oil cap. The tank and dash console are the same as the earlier models. I can't think of any reason why this speedo (which claims to be plug and play) shouldn't work in the 10/11 wg, unless maybe the wiring harness is different? Any of you guys tried it yet?
I looked into this a little already, the size is the same, but i looked up the part numbers on the wire harnesses in the console between the 2010 wide glide and the 2012 wide glide and they are different.
The only thing i can think of is that the 2012 wideglides display a tach and have a gear indicator built in.
So I was hoping someone would buy one and try it out so i could know if it works!
You are correct, the 2012 WG stock speedo supposedly also displays tach and gear indicator as well, where the 10/11 models don't...however, I upgraded mine already with a Dakota Digital speedo--straight plug and play--and that speedo also displays RPM, gear position, and low fuel and the information displays just fine--so that information is still transmitted over the stock 2010/11 WG wiring harness, I would assume?
It's an expensive gamble to take, but I still can't see a reason why this wouldn't work from any research I've done. I don't know...maybe there are some other features that wouldn't work?
Thats good info right there, i wasnt sure if the connector was the same on the back of the cluster, bc according to the dealers parts catalogue the harness ARE different....
I might try to ride to the dealer and just test it out in the parking lot if they let me
