one LED or two halogen's ??
which do you think would give more usable light , one 5 3/4 inch LED headlight or a dual 4 1/2 inch h4 style bulb set-up ?? (dual LED is out of my budget range)
Never seen those two compared side by side. Have you seen the video of the 5-3/4" HD LED compared to the single 5-3/4" H4? The LED is many times brighter. That's what I went with.
I don't think its that simple. The LED lamps tend to be brighter (but beware cheapo ones off eBay, some of these are dimmer than George Bush) but have a narrow beam. Halogen lamps tend to be slightly less bright but give a wider beam.
This actually makes a big difference at night, with LED lights not giving that whole-road view that is actually really important. |
I just recently did a comparison of my fat bob headlight (dual led w/ silver star bulbs) vs the Harley 5 3/4 LED light. I was expecting it to be a close call but it wasn't, the led blew the fat bob light away, there was just no comparison.
Here is a picture of it on the bike: http://img824.imageshack.us/img824/8021/photolfq.th.jpg |
The Speaker H-D LED lamp is actually 4 LEDs in 1 lamp. 3 burn at any time low beam or high. Being projector lamps alinement is important as the beam is focused and not spilled all arround. The only problem with this is when you lean into a curve your beam is not floody enough to light up the road as well as the moore floody non projector incandescent lamps.
Billy |
Love my led!
Originally Posted by Billyram
(Post 8859589)
Billy |
so LED is the way to go then ?? I watched the harley video clip but never trust advertisement , they can make crapy things look great but if ya'll are running them and say they are that much better thats what I will go with. really thought a dual light set-up would have given them a run for the money....those LED lights must be pretty dang bright
Here are some pictures that I took of the light pattern produced by the H-D LED headlamp, both low and high beam. This was a new subdivision street with no trees or weeds, so it's hard too really see how well the high beam works with the light going off into endless black space.
http://www.smokypond.com/gallery/dow...2/IMG_0251.JPG http://www.smokypond.com/gallery/dow...2/IMG_0252.JPG |
As mentioned earlier, just get it aimed right. And the only thing I don't like is sharp curves at night. If it says you have to buy a different light housing, do some research.i ordered the housing because the box said I needed it. Two days later I decided to try out anyway and it went right in just as easy as the factory reflector and works fine.plug and play!
| All times are GMT -5. The time now is 05:55 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
