Cable length for Chubby's??
I have a 98 WG that is going through some changes. I purchased a set of Wild1 Chubby's and I am wondering if anyone else could tell me the length of the throttle, idle, and brake line they used? I ask because I have heard anywhere from 6" to 12". I did some rough measurements and I came up with 8", so you can see where my confusion is. I am keeping the stock 2" risers and I have a jockey shift/suicide clutch so I don't need the clutch cable lenth.
Thanks, Phil |
RE: Cable length for Chubby's??
What size are your bars
I have 16 inch chubbies.
I went 10 over on the throttle and idle cables 8 over on the front brake cable 10 over on clutch I have a few inches of growing room, thinking of getting 3 or, 4 inch risers. If your sure your going to just put the new bars on then, I would go an inch or, 2 over what it will take. 10 inch to 12, get 3 inch over...and so on. You'll have to think about the movement of the handlebars. |
I have the 16 inchers as well. Thanks HDWG I will try those lengths.
| All times are GMT -5. The time now is 04:12 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
